KFX 90 popping
Old Oct 18, 2006 | 12:06 PM
WesB's Avatar
Default KFX 90 popping
My son's KFX 90 makes a popping noise when he has it really torqued up (climbing hills mostly). Anybody got any ideas on what this is? It's usually 2, 3 or 4 quick pops like something is slipping. Also any tips on getting more out of it? It runs around 30 on top and comes out of the hole quick enough for his current skill level but I might want more one day.
Old Oct 18, 2006 | 12:39 PM
LT80's Avatar
LT80 Expert
Is this the 2007 model or the 04-06 KFX/LT80?
Regardless, I'd clean the carb just to make sure it's not got a jet plugged. If that's ok, try raising the needle a notch.
Old Oct 18, 2006 | 06:18 PM
oldyeller's Avatar
Is the popping from the exhaust or a mechanical type sound?...By LT80s response I'm thinking he means if the popping is coming from the exhaust because of an engine miss..
Old Oct 19, 2006 | 09:41 AM
LT80's Avatar
LT80 Expert
Unsure Yeller. [img]i/expressions/face-icon-small-smile.gif[/img]
with the suz-kaw split, kaw went on it's own for 07 (90% sure) so this could be a 4 stroke which would effect a recomendation.
I always start with a carb cleaning as it's easy and no cost.
Old Oct 19, 2006 | 03:43 PM
WesB's Avatar
This is the 07 4-stroke. It has less than 5 hours on it and has done it since I took it off the truck. Its a mechanical noise and is worse when I put my 195lbs on it. I only hear with my son when he is going up steep inclines. Sounds like something slipping.
Old Oct 19, 2006 | 06:08 PM
LT80's Avatar
LT80 Expert
Valve lash not correct????
Jetting??
it only does it 2-4 times then is OK or by then is he up the hill?
Old Apr 27, 2008 | 03:42 PM
mikeseldomridge's Avatar
Yea i had the same prob i found out it was the chain slipping off the back clog it never popped off just slipped therefor making a popping sound.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
r1pilot83
Sep 27, 2015 07:38 PM
Rooky
Sep 9, 2015 03:16 AM
