giovanni advice needed
Unpacked a new gio 50 today and run into a problem. After changing oil and starting it, it only runs with the choke on. If you take the choke off, it idles too slowly to run more than a few seconds. It quits even if you "feather" the throttle with the choke off, but seems to run fine (although fast) with the choke on.
Does this sound like a problem with the gel pack? Does the idle screw on the carb need some adjusting?
Any other ideas?
Thanks.
Any other ideas?
Thanks.
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
