need to clean carb on raptor 80
Old Mar 26, 2007 | 10:28 PM
KEGRACING's Avatar
Default need to clean carb on raptor 80
I have a 03 Raptor 80 that I bought a while back, that had sat for about two years. I have already pulled head and put new rings and piston, due to being stuck. Exhaust valve was open when parked... my luck.
I pulled the carb, and it is full of the dreaded white powder gunk! I have tried carb cleaner, brake cleaner, gas, etc. I have scraped a lot of it off, but it will not wash off, and carb will not idle well and is very rough until you get RPM's up. I know its got to have the white stuff in the circuts... I have pulled both jets, float, etc. and sprayed and soaked... still rough and idles really low and idle screw does not help.
Has anyone found anything that will remove the while powder stuff?
Thanks for the help!
Ken
Old Mar 26, 2007 | 10:33 PM
2manytoys's Avatar
White stuff? I would soak everything in gas for a few days then blow out the jets or use a needle to clan the jets and put it back together.
skinnyr6
Aug 25, 2023 02:18 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
tweeder
Jul 5, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
yambam13
Jul 4, 2015 01:49 PM
