2004 eton 90 viper won't move
Old Apr 19, 2007 | 11:23 PM
rdecook's Avatar
Default 2004 eton 90 viper won't move
The bikes starts, idles fine, when drive line has no pressure (like on the block) it runs fine. As soon as you put pressure on the drive line it bogs out, but keeps running. It will not move. I've replaced carb, reeds, exhaust system, piston and rings, stator plate, key switch, and all the bearings in the final drive shaft. Also, the Eton dealer cannot figure it out. Does anyone have any suggestions for this problem?
Old Apr 20, 2007 | 12:32 AM
oldyeller's Avatar
Are the rollers in the variator installed properly?..It sounds like it might be something in the transmission instead of the engine...Do the rear tires turn freely?...I would pull the belt cover and take a look in there.
Old Apr 21, 2007 | 08:35 PM
superbombman's Avatar
Yeah what oldyeller said also to un bolting the exh. from the head and see what happens
Old Apr 25, 2007 | 01:57 PM
Maddoggy's Avatar
Remove the spark arrestor from the muffler.
they get clogged and restrict the muffler. Just like the banana in the tail pipe trick.
Old Apr 26, 2007 | 02:45 AM
elroy1's Avatar
It does sound like it could be a clutch issue. If the torsion spring has taken a dump on you that is pretty much the effect. Also if your rollers are deformed or wedged in the front clutch, that could be the result. I'm assuming that you or the dealer you took it to checked the compression.
Old Apr 26, 2007 | 07:32 PM
rdecook's Avatar
yes i rebuilt the whole motor plus put brand new exhaust new pistonand rings bearings reeds carb cdi stator plate and key switch.
Old Apr 12, 2018 | 01:08 PM
Clinton Zimmerman's Avatar
2006 Eton 90cc 2stroke
My rear centerfuge clutch would not engage. It would grab and as soon as it loaded it would let go. Bike would hop but not move. New rear clutch, New Variator, New Carb, New Coil and Plug, New piston. Large amount of smoke at all times. I finally found the problem. The rear spark arrestor was fully plugged. Cleaned it and reinstalled. Bike ran and engaged great for about 30 seconds until the spark arrestor clogged again. The exhaust pipe/muffler is full of oil/debris from the spark arrestor being plugged. Need to remove exhaust pipe. Clean and reinstall.
Hope this helps someone else. Pull the spark arrestor out of the back of the tail pipe. See if it moves after.
Old Apr 13, 2018 | 04:28 PM
LT80's Avatar
LT80 Expert
No offence, but we would have told you that long before all the money spent.
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Bernhard
Sep 25, 2015 12:45 PM
Sw00p
Sep 24, 2015 02:50 PM
