LT80 A-Arms and suspension
you can get more travel by replacing the shocks (works brand). a no cost way to widen your lt a little is to flip your wheels around, because there is an offset you gain an inch or two .the only prob is your valve is now on the inside. but watch your tread rotation, and your front valves may touch the brake cable or the arm. my sons lt80 has short valves so it clears. good luck
With a stock motor I used a skat trac glider with 5 paddles. They worked great until I did all the motor mods. Now I run a 6 paddle hauler! Make sure to stay with a 18 inch tall tire, not a 20inch. Don't buy a gecko, they are too heavy! You can get rims with a different offset to widen your rear without using wheel spacers.
