dinli 50 carb problems
Old Aug 20, 2007 | 11:10 PM
dmonticello's Avatar
Default dinli 50 carb problems
Need help, my sons dinli 50 leaks from the overflow, or what i think is the overflow from the bottom of the carb (tube), I tried tightening the plug screw but it still leaks, it runs great but leaks continuely when riding or when I shut off, Any suggetions?
Old Aug 22, 2007 | 05:59 PM
powerfool's Avatar
darryl,
Chances are very good that the carb. is overflowing due to the needle valve sticking open. Most often when this happens, it is the result of debris getting between the needle valve and the seat- preventing it from completely closing off the fuel flow to the bowl. With it not closing fully, gas continues to rush into the carb. causing it to overflow out of the overflow tube.
What you need to do is:
1. drain the carb
2. remove the carb for ease of access (optional)
3. remove the float bowl
4. remove the floats and needle valve by pulling the hinge pin out of the float (careful not to lose anything and note how it goes back together)
5. inspect needle valve and seat for debris and clean as needed
6. reassemble
HTH,
Steve
Old Aug 22, 2007 | 08:04 PM
Thanks
Old Aug 22, 2007 | 08:23 PM
AIRMOBILE101's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: powerfool
darryl,
1. drain the carb
6. reassemble
HTH,
Steve</end quote></div>
Is it it your drain tube? The tube that extends down from the carb? your drain **** screw is probably stripped. Also , if the needle sticks , good chance fuel in your air filter box .
Ty Speece
Jul 2, 2015 04:59 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
