95 LT 80 Starting Problems
Old Sep 25, 2007 | 02:10 PM
sandridergp's Avatar
Default 95 LT 80 Starting Problems
Hey guys, i am having a problem getting the little guys 80 started. I am currently charging up the battery as we speak. When i try and start the quad i am getting a slight click to the starter relay but nothing else. Any Suggestions?
Old Sep 25, 2007 | 04:30 PM
cubano222's Avatar
May be the starter solenoid. Put a screwdriver across the 2 wiring points on the solenoid & see if the starter turns.
Old Sep 28, 2007 | 01:38 PM
LT80's Avatar
LT80 Expert
There are other threads on this subject I'm sure.
Sorry, electrics are not my specialty.
To check to see if it's the starter or another problem, you can put a 12 volt source (battery charger/jumper cable) directly to the starter. Stand the machine on end (for access) to try that.
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
