I need some help? my 200cc wont start
Old Nov 5, 2007 | 05:06 PM
  #21
sunl250kla's Avatar
Default I need some help? my 200cc wont start
ya hondarider27, remember when i told you about my carb? well, i tried adjusting my floaters so they were level with the carberator case. It still doesnt work. Damn piece of crap. I'm just gonna buy a new carb, but thanks.
Old Nov 5, 2007 | 09:54 PM
  #22
outofline's Avatar
It's kind of a fine adjustment, if you go to high no gas will enter the Bowl, if to low it will over flow. After you adjust it open the drain screw and make sure it is in fact filling the bowl. If your jets are clean and not plugged and your float is adjusted correct a new carb won't make any difference!
If I were you I would shut the gas off, drain the carb hit the starter (with plug out) for a few. Put the plug in hook up the spark plug wire, give it a shot of starting fluid into the air filter and start it and see if it will run for a bit off the fluid. If it will then it is still the carb that is the problem. Carbs just don't go bad, they get plugged.
I don't recall, did your 200 ever run normal? or is this a new set up problem?
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
Rudnik
Dec 31, 2001 06:02 AM
