JetMoto Finally Arrived
Old Dec 15, 2007 | 09:55 AM
balanis03's Avatar
Default JetMoto Finally Arrived
I finally put together my Jetmoto 250cc sport. I rode for about 20 min yesterday and everything was fine it started up on first crank but this morning i woke up to the smell of gas and checked on the little bogger and had leaked a significant amount of gas overnight. The fuel filter was just dripping and dripping so i had to drain the Gas. Any idea WHY. Last night before going to bed i tried starting the thing and didn't start after 3 times but noticed the switch was to the off position. could that have something to do with it? I need some help and i believe raceway don't open today.
Old Dec 15, 2007 | 10:03 AM
KINGQUAD450's Avatar
sounds like the float is either sticking or set to high
Old Dec 15, 2007 | 10:13 AM
balanis03's Avatar
how do i fix this?
Old Dec 15, 2007 | 10:39 AM
billl2099's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: balanis03
how do i fix this?</end quote></div>
only one way to fix it, dumpster
Old Dec 15, 2007 | 11:59 AM
balanis03's Avatar
Just to let you know all bikes sometomes have this problem your so negative dont you have anything better to do!!!!!!!!!!!!
Old Dec 15, 2007 | 01:33 PM
outofline's Avatar
"The fuel filter was just dripping and dripping"
He said the Fuel filter was leaking, I had a fuel filter on my Jet 250 started leaking but this was after a few months of riding. These are cheap filters that need to be replaced asap. Go to your local motorcycle shop and by a new universal inline filter! I heard Autozone may have one also! You may want to replace the fuel line also, it's pretty cheap stuff Jet puts on there!
If your float is in need of adjustments it would be leaking out of the tube on the bottom of the carb!
Old Dec 15, 2007 | 01:37 PM
billl2099's Avatar
whats sometomes mean?
Old Dec 15, 2007 | 01:54 PM
<div class="FTQUOTE"><begin quote>Originally posted by: outofline
If your float is in need of adjustments it would be leaking out of the tube on the bottom of the carb!</end quote></div>
My bad I miss read it I thought he said air filter sorry.
Old Dec 15, 2007 | 03:04 PM
outofline's Avatar
Bill, back away from the keyboard!
Why don't you go riding and get rid of some of your built up anger, or is your Cat broke right now?
Old Dec 15, 2007 | 05:28 PM
billl2099's Avatar
Why don't you go riding and get rid of some of your built up anger, or is your Cat broke right now?</end quote></div>
hey anyone that can't figure out how to fix a leaking fuel filter and needs to ask how has no business owning a chinese atv period!
