Kazuma 50 lots of oil out exhaust
Old May 31, 2008 | 08:26 AM
89stp's Avatar
Default Kazuma 50 lots of oil out exhaust
Are you sure it's oil? If it is oil I doubt that your problem would be the rings, if enough oil is getting past the rings to run out the exhaust and not get burnt the engine would not run or it would hydro lock. If it is oil then it would probably be getting in to the exhaust after it leaves the combustion chamber. If that much oil was in the combustion chamber the plug would not be clean.
Old May 31, 2008 | 11:26 AM
holtzer1's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: pldtj5
or ya could just do what holtzer is doing and spend 3 times as much on a quad your kid will outgrow in a yr or so. I like the chinese quads for the reason that they are cheap enough to fix or replace till the kids get experienced and grow enough to spend thousands on a quad that they will not outgrow.</end quote></div>
you might want to take a better look at the brand name quads. their chassis are alot bigger than the imports. my 5 yr cant even fit his feet in the kazuma floorboards, when he's sitting on the kfx, he has planty of room to grow...my 9 yr old sits comfortably on the kfx. the whole "kids will outgrow them in a year s a BS copout and is way overused with no real evidence to back up the ridiculous claim.
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
Divergent12
Dec 30, 2017 08:33 PM
rjacree
1) Engine problems..
Aug 3, 2015 10:21 AM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
