Understanding the used 48cc chinese quad I just acquired
Old Dec 18, 2008 | 12:31 AM
  #31
onebigzj's Avatar
Default Understanding the used 48cc chinese quad I just acquired
you should have four gears. look on the bottomof the motor by the left (sitting on it )foot peg for a shaft with teeth. that is where the shifter should. any honda gear shifter should work. and the same with the screw and spring for carb. go to honda or e-bay
Old Jul 12, 2022 | 01:58 PM
  #32
Lonely56's Avatar
Default I have one like this, what make is this? Trying to find a wiring diagram for this mam
Hi. What machine is this? I have one but all it has on it is the model- Motorfist. I need a wiring diagram
Originally Posted by jason4207
It has the single disc brake on the back axle, and that's it...no brakes up front.
So, the red switch is a kind of kill switch? The starter system works w/ it in either position.
Here are some more pics of the work in progress:
Before I tore the carb apart
Attachment 24038
Attachment 24039
Carb torn apart...after a whole can of spray carb cleaner...not clean enough, so it's soaking in parts cleaner now.
Attachment 24040
A few more questions:
1. Motor oil...I want to change it...can I use the Mobil 1 synthetic 5W-30 that I already have? I also have some John Deer (I think it's 10W-30) oil for mowers/small engines.
2. Approximately how much oil do these engines require?
3. Where do you fill it up at? At the dipstick?
4. Is there any kind of oil filter or screen on these engines? If so, where is it located?
Frisky2050
Apr 9, 2020 11:19 AM
Ripinandtearin
1) Engine problems..
Dec 11, 2017 08:06 PM
Chillibean
Jul 26, 2015 09:47 AM
Waddell4436
Jul 20, 2015 09:46 AM
Ripinandtearin
Jul 19, 2015 08:38 PM
