Hi-Bird 250 brake bleeding?
Old Jan 9, 2009 | 04:34 PM
chrisely24's Avatar
Default Hi-Bird 250 brake bleeding?
I toook the whole brake system off and managed to get the fluid to travel to the caliper. I am guessing there is alot of air in the system and it won't build up enough pressure to force the pistons out to the pads.
Anyone know of a way to bleed that system?
Old Jan 10, 2009 | 12:55 AM
LynnEdwards's Avatar
Electrical Expert
Are you asking how to bleed a brake system in general, or are you saying you've used the traditional methods and they don't work?
Old Jan 10, 2009 | 08:27 AM
chrisely24's Avatar
Well, I tried to bleed it like you would do on an auto, open bleed nut pump until it squirts out then hold brake pedal and re-tighten. But thats all i know to do and its not working for me.
Old Jan 10, 2009 | 11:43 AM
Electrical Expert
You aren't alone. Please see this post from a few days ago:
Another Bleeding Brake Problem
I've now seen a third method posted to solve stubborn brake bleeding problems: Use a MightyVac vacuum system to suck the fluid out the caliper. All the necessary stuff comes with the MightyVac kit. I seen these at Harbor Freight for around $30.
If it were me I'd try the oil can method first. The oil pump cans at Harbor Freight are only around a dollar.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
