eton viper 90 r neutral light flashing won't start
Old Mar 14, 2009 | 08:05 PM
tokar's Avatar
Default eton viper 90 r neutral light flashing won't start
hi, i took my E-ton Viper 90R (2004) to the shop last august because it wouldn't start. i replaced the spark plug and it worked for about a day and then it just wouldn't start. all this began last June, when the frame broke and a friend of mine welded it for me! After he did that it worked but when i shifted into reverse the battery would drain completely and need to be jumped! So after that happened i took it to the shop and they said there was burnt wires and no spark. I was thinking of buying a CDI box, but i wanted to know what you guys think. Also the neutral light flashes if that helps at all
Old Mar 16, 2009 | 02:05 AM
95wolv's Avatar
You may have fried the CDI with the welder, the quad grounds everything to the frame, when you weld it, you put a pretty huge voltage spike into the frame,you should unplug the voltage regulator and cdi whenever you weld on the frame. Also, run the ground clamp for the welder as close to the work as possible, to limit the stray voltage traveling around the frame, looking for a good ground.
Old Mar 16, 2009 | 12:40 PM
tokar's Avatar
Thank you for your reply man. that's what i thought i was quoted about 200 $ to install it so i think i might ust get my other ATV fixed
Old Mar 17, 2009 | 06:56 PM
twister500's Avatar
Try this.
http://www.etonamerica.com/PDFs/WP0020.pdf
Dabears1983
Jun 16, 2015 12:17 PM
jag6510
Jun 15, 2015 05:59 PM
jayking232003
Jun 9, 2015 02:54 PM
Fnqrider
May 31, 2015 08:29 AM
1000gade
May 27, 2015 12:37 PM
