cylinder issue on eton 70
Old May 7, 2009 | 06:55 PM
sand45's Avatar
Going over bore should not require a bigger jets.
Old May 7, 2009 | 08:40 PM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
Originally Posted by vindell
just got a pre-owned koso cylinder, piston, and new ring's. installed. doas not seem to have the same low end power. Only rode it about 30 minutes total. seemed to pull more mid to top end. Stock machine other than slighly ober bore. what is going on, carb to small, increase size of jet, clutch?
After my pipe and cylinder kit, mine liked rpms. I'd try a some stiffer springs and lighter rollers. Also, WRH Racing has an aluminum clutch that I really like.
Old May 7, 2009 | 09:55 PM
oldyeller's Avatar
Maybe the koso cylinder has different porting more suited to high rpms..You could try some lighter rollers in the front variator or stiffer springs in the rear clutch to help get the rpms up off the line and into the power band..
Old May 9, 2009 | 05:04 AM
vindell's Avatar
prior to replacing cylinder, got some advice to switch belt to a 877 bando.
decided to take a look at belt, looked as though it was too loose, put stock belt back on now the thing is running real good. cannot beleive the differance this koso cylinder made. getting a clutch kit installed on monday.
Old May 13, 2009 | 11:04 PM
  #15
riding4fun's Avatar
877 belt is way to big. Did you mean 787 belt?
Old May 14, 2009 | 06:53 PM
  #16
vindell's Avatar
not sure of belt size, however decided while at shop, I'd have the clutch kit installed and add a drr pipe, keihn 20, koso intake and reeds. Removed oil injection system prior to visit to shop. Took it to Kool kidz atv, in Jersey. The fella's mane is Corey, pretty fair guy. Pick it up Monday, Looking forward to running it. Will it be night and day performance over stock machine. Or just a little quicker over the stock machine.
Guess I'll get a a set of wheel's and tires next. Should I go with 8" rear and 10" front, seem's to be the standard set-up? As well as a set of front shock's. Will the stock clutch support the new motor mod's. I have a ton of question's as you can see. Any input would be appreciated.
Thank's Vince
Old May 14, 2009 | 09:50 PM
  #17
nkkiegem123's Avatar
im switching to 787 belt
Old May 15, 2009 | 06:20 PM
  #18
vindell's Avatar
first mini two stroke, what kind of increase in performance can I expect?
It's killing me . Pick up on Monday. Night and day or so so diff.
Ramman1
Jun 16, 2016 09:07 PM
cody500ho
14
Aug 14, 2015 05:03 PM
DeFox500
Jul 26, 2015 06:32 PM
Unzzy66
Jul 11, 2015 10:01 PM
MNatv89
Jul 7, 2015 11:36 AM
