gutless yerf dog 90cc
Old Sep 20, 2009 | 01:36 AM
daddyo4's Avatar
Default gutless yerf dog 90cc
Im new to the forum so hope I did this right. Just bought a '01 yerf dog 90cc real cheap. It runs, pain in the butt to start though. Once started it will run for about 5 min. then dies. It will start again and run for about the same amount of time before dying. Thru all this the quad loses power, bad. I think it may need a rebuild. How do I check the compression? Is it the same as with a V-8? And does anyone know if a big bore kit can be installed on this brand of quad and if so where I can get one? Just trying to be brief and to the point. Thanks
Old Sep 20, 2009 | 07:58 PM
verl's Avatar
Hi,
Check the exhaust first and see if it has a screen (spark arrestor screen) remove it. Also check the intake filter and tube for any obstructions, restrictions and remove them. If you have a compression tester a fresh (new) motor should test around 140+. If you need parts check out an ebayer named autotech355. He sells lots of aftermarket parts for these yamaha jog type 50/90 2 strokes.
Cheers!
Old Sep 21, 2009 | 11:22 PM
daddyo4's Avatar
Hey verl, thanks for the info. Im gonna pick up my compression tester from my dad's house tomorrow and check it out. But I will make sure there are no obstructions first.
Old Sep 22, 2009 | 07:23 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum daddyo4!
Id start by checking compression....
Old Sep 23, 2009 | 10:57 PM
rudbirspi's Avatar
Default Thanks
edited by atvconnection moderator
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
MrTrashMan2U
Sep 9, 2015 11:44 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
AlotL1keVegas
Aug 18, 2015 09:38 PM
