Chirp sound
Old Mar 15, 2010 | 03:56 PM
blevinsbulldog's Avatar
to me Standing beside of it, it kinda has the same sound as a bearing going bad (metal on metal). That whats got me though. I can only here it when i shut it off, not saying it only does it when i shut it off, thats just when i here it & it dont do it all the time, just most of the time.
Old Mar 17, 2010 | 03:51 AM
ttt
Old Jun 19, 2010 | 08:29 AM
Rude Robert's Avatar
what did u find out
Old Jun 19, 2010 | 12:21 PM
nothing....Still going strong! (shrug)
Old Jun 26, 2010 | 09:50 PM
  #15
papa hogg scoot's Avatar
Loved
Community Favorite
It sounds like the reeds values ! does it only do this when you shut it down?
Old Jun 27, 2010 | 09:44 AM
  #16
the only time i notice it is when you shut it down. It dont do it every time, just most of the time. I turned the idle down to let it lug down & i cant tell if its doing it then or not. Im not real sure what you mean by "It sounds like the reeds values !"
Old Jun 27, 2010 | 10:52 AM
  #17
Loved
Community Favorite
Does atv start good? if hard to start your reeds have trash r screw coming out of them. the reed cage is behind carb.mount. BUT if start good then I would say thats normal when shut off because compression of engine is opening and closing reeds and you are hearing the values coming to an stop.IMO.
Old Jun 27, 2010 | 06:57 PM
  #18
the first start of the day requires the use of the choke & starts in no more than 2 seconds. after its warmed up & you start it it only takes a tap of the starter to get it started. it starts & runs great other than only getting 21mph top speed.
  #19
mbarryracing's Avatar
That sounds like the clutch bell of a centrifugal clutch ringing from torsionals as the crankshaft is jerking to a stop.
Either that or the sprague clutch (one-way bearing) for the starter motor.
Old Jun 27, 2010 | 07:02 PM
  #20
either one to worry about?
