Lt80 mods! Got some questions?
Old Jun 26, 2010 | 09:19 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Default Lt80 mods! Got some questions?
We have an Lt80 that we bored to 51.50mm and goin to block off oiler and what is an good ratio to mix with amsoil? what should my piston and cylinder clearance should be? ring end gap? we already have carb. ported and fmf pipe, gear ratio changed, just curious bout fuel ratio? Thanks in advance.
Old Jun 27, 2010 | 08:39 AM
LT80's Avatar
LT80 Expert
What the oil says to mix at. Most amsoils are 50:1.
Clearance should be .003- .0035...
Old Jun 27, 2010 | 08:46 AM
Loved
Community Favorite
Thanks LT just geting advice from other to see anyone have had problem mixing 50;1
Old Jun 27, 2010 | 07:05 PM
mbarryracing's Avatar
We've run over 50:1 with amzoil for trail machines, been up to 100:1 on race machines with a high end synthetic.
When building a modified racing 2-stroke, good rule of thumb is the more HP the engine is makeing after being modified, the more additional cylinder clearance you'll need above stock. HP makes heat, heat grows pistons, especially in an air-cooled motor. If you are going to run stock clearances, better run an oil mix more like 32:1.
We run 0.006" with cast pistons, Wiseco's need even more to prevent sticking because of their thermal expansion rate.
Ring end gap, not more then 0.007"
Old Jun 27, 2010 | 09:57 PM
2strokezilla's Avatar
have used MC1 for years at 50:1 the LT80 is a great machine there is lotsa mods for it
Jaymc
Sep 11, 2015 07:45 AM
cornermike
Sep 10, 2015 08:30 AM
Rooky
Sep 9, 2015 03:16 AM
bmark0610
Sep 7, 2015 09:42 PM
JakeXBL
Sep 5, 2015 01:08 PM
