Chinese Quad SLA 200 KS
Old Jan 16, 2011 | 11:12 PM
LynnEdwards's Avatar
Electrical Expert
Is this access hole right over the flywheel? Quads often have a view port access hole in the cover over the flywheel in order to shine a timing light onto the timing marks on the flywheel. New quad owners sometimes pour oil into this hole by mistake.
Old Jan 18, 2011 | 01:19 AM
weiry84's Avatar
Well i got the magneto out and the two wires green/white stripe and the blue/ white stripe goes into the pickup and the three yellow wires go round the coils. i can only get 136 ohms between the blue/white and green/white wires? is this good or not? cheers
Old Jan 18, 2011 | 09:14 AM
Electrical Expert
136 ohms is fine. The better test is to see if you get 0.2 to 0.4 volts AC on these wires with the starter motor cranking.
But you measured infinite ohms on these very same wires when probing from the CDI connector. So it looks like there is an open wire between the CDI connector and the stator.
Old Jan 18, 2011 | 12:33 PM
weiry84's Avatar
yes thats right so what ill do is put it all back together and try and get that 0.4v whilst cranking it over and also try and get the resistance from the CDI on those 2 wires. ill let u know how that goes!
Old Jan 18, 2011 | 12:35 PM
  #15
weiry84's Avatar
When i removed the magneto there was a few cogs in there and also a bit of oil any idea what type of oil would be in there? the cogs join the starter motor to the flywheel im guessing!
Old Jan 19, 2011 | 12:51 AM
  #16
weiry84's Avatar
so i got .245vac from the wires with it cranking and also got 140 ohms from the cdi so im guessing the magneto is all good! so where do we go from here? im a little concerned that the solid black wire that should be the ac ignition power goes to nothing? should i try and put 12vdc through this see if this works?
Old Jan 19, 2011 | 12:56 AM
  #17
weiry84's Avatar
Mate just got her started black wire into the cdi was 12v positive therefore it is now sparking and running! Thanks heaps for all your help cant beleive i got it going with all your help! many thanks Nick
Old Jan 23, 2011 | 11:36 AM
  #18
Electrical Expert
Nick, I'm glad you got it running...
I apologize for the last several days of silence. I've been flat on my back with the flu. It looks like you were able to solve it yourself .
Lynn
Frisky2050
Apr 9, 2020 11:19 AM
Ripinandtearin
1) Engine problems..
Dec 11, 2017 08:06 PM
Waddell4436
Jul 20, 2015 09:46 AM
Ripinandtearin
Jul 19, 2015 08:38 PM
Waddell4436
Technical and How-To Articles
Jul 19, 2015 04:22 PM
