eton rascal no spark
Old Jun 20, 2011 | 09:25 AM
shopguy's Avatar
Default eton rascal no spark
Hey fellas, Maybe someone could show me the thread for this or just tell me what's up with this thing. I've got a 2000 40 cc rascal with no spark. I pulled the cover off and cleaned the coil and pick up. Tested the pick up and it shows good, getting a pulse on the ohm meter anyway. The coil shows open no matter what terminals I test. There are two terms on the coil and the plug wire. Is this thing bad? I figured I'd have seen some kind of resistance across the two terms on the side of the coil but not savy enough to know. Also how do I test the trigger module, I take it that's the little black box with the reostat to set the rev limiter. I've givin the coil the evil eye until someone can tell me different.
Old Jun 20, 2011 | 11:27 PM
LynnEdwards's Avatar
Electrical Expert
I know nothing about this ignition system, but the coil should have a connection to ground from both the primary input, and from the coil output wire.
The first (primary side) should be a really low value less then 1 ohm, the secondary side should read tens of ohms to many thousands of ohms depending on whether a RF suppression resistor is built in.
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
hueby
1) Engine problems..
Aug 29, 2015 08:34 AM
hueby
Aug 28, 2015 07:26 PM
mbkirk
Aug 14, 2015 08:20 PM
mbkirk
Technical and How-To Articles
Aug 14, 2015 08:12 PM
