Another stubborn Alphasport 90 owner
Old Aug 10, 2011 | 06:55 PM
lizardman's Avatar
Yep, I am still scratching my head.
I now have fire to the plug, but apparently the plug being a little wet does not translate to enough gas going out of the carb to the cylinder.
The starter will just turn away, but nothing happens.
I squirted a little gas into the spark plug hole and boom, it started right up until it burn that gas.
I have gas in the tank, the petcock flows fuel, the filter is installed properly and gas flows thru to the carb. Also, when I unscrew the bowl screw, gas pours out. But, nothing apparently is going to the engine.
So, I guess I have to pull the carb and try cleaning it again as I can only figure that I missed whatever is clogging it up.
Is there any particular thing that I need to check or clean on the carb? The only adjustment I can see is one screw that I have no idea how to adjust it properly. Is this the needle or just the idle adjustment?
I feel like I am so close, and it is just frustrating that it refuses to run for me.
Rod
Old Aug 20, 2011 | 09:47 PM
lizardman's Avatar
Default Finally got the chance to pull the carb
I cleaned it as well as I could. I took out overy screw possible and blew it out with the air hose.
I got it back together, and it cranked in less than a second.
To begin with, it bogged down at about mid-throttle. After a little run time, it doesnt bog as bad, but I wonder if there is a carb adjustment that I have wrong. Or, if there is some governor that I have missed to keep speed low?
The throttle goes all the way, so I know its not on the handle bar.
Thanks for your patience and help.
Rod
Old Aug 27, 2011 | 02:47 PM
lizardman's Avatar
Default Unbeleivably, I STILL need help
After the atv ran perfect last weekend, it wont start again. This time it is due to no spark.
I cant understand how it ran great the last time it was touched, and now something is wrong. I am so PO'd at this machine.
Can someone point me to where to look to find its fire again?? Everything appears to be hooked up, and as said before, nothing has changed with the atv since last weekend.
Rod
Old Sep 3, 2011 | 08:49 PM
lizardman's Avatar
Default Still need
HELP!!
Still no luck with fire, and I dont know what else to check or do.
Any ideas?
Rod
95wolv
Sep 27, 2024 12:00 PM
Joe454
Nov 20, 2020 01:19 PM
Customer Service #1
May 15, 2020 08:46 AM
wendal
Oct 31, 2017 03:31 AM
Ahtatu
Sep 28, 2015 12:14 PM
