Eton viper 90cc
Old Dec 15, 2011 | 02:41 PM
ethlewmum's Avatar
Default Eton viper 90cc
Just bought two Eton Vipers 90cc, need to know how to take off the carb as when I am giving it throttle there is no power could this be starvation of fuel or does the carb need cleaned ?? If so how do i take the carb off to clean it, is it easy to strip the quad etc, new to this stuff !!
Old Dec 16, 2011 | 07:21 AM
JTolliver's Avatar
When you say "no power" is it bogging, or does it sound like it's cutting out (rev limit)? '05+ have an adjustable CDI (under seat, beside battery), look for a small rotary dial on the back (small screwdriver to adjust). It could be as simple as that being set on too low a setting, limiting the revs.
Beyond that, check fuel filter & petcock before pulling the carb., but no, there's nothing to these little guys. I've had ours down to bare bones and back already, and the kid doesn't even know it exists yet (spit shining his Christmas present).
Old Dec 16, 2011 | 08:26 AM
Jaster94's Avatar
are these new or used quads? if used, you may want to pull a compression test and look at the clutch adjustment.
if new, look at the clutch adjustment and see where it is set at. i'll send you a PM with the necessary info for the clutch adjustment.
Old Jul 10, 2013 | 06:36 PM
gschofield's Avatar
Default new eton viper 90 cdi limiter
I just bought my kid a new eton viper 90. There doesnt seem to be any sort of cdi rev limiter adjuster anywhere. The engine retards at a very slow speed. On the new viper 90s does anyone know how to remove the limiter?
Old Jul 12, 2013 | 06:31 AM
Jaster94's Avatar
sorry i don't. have you contacted Eton directly? they ought to be able to walk you through it.
Old Jul 15, 2013 | 08:48 PM
LT80's Avatar
LT80 Expert
I wonder what restrictors that machine comes with.
Sometimes a throttle and/or clutch limiting device.
flyin-lowe
Dec 1, 2017 03:18 AM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
Minimod
Sep 10, 2015 09:20 PM
MrTrashMan2U
Sep 9, 2015 11:11 AM
