2007 Kfx 90 problems????
Old May 23, 2012 | 03:08 AM
Lander Walker's Avatar
Default 2007 Kfx 90 problems????
Hey, my kfx 90 it sat for about a year and I tried to start it sat there and sounds like it's not getting gas and just about to turn over... I put gas in the spark plug and it ran for about 10 seconds?? Anyone know what's wrong or how to take off the plastics because it has the snap on plastics and would at least try to look at the motor and try to find the problem? Thanks!
Old May 23, 2012 | 05:57 AM
Jaster94's Avatar
pull the carb apart and clean it. the jets are plugged. you have a fuel delivery issue.
how to clean a carb on a ATV - YouTube
Motorcycle/ATV carburetor diagnosis - YouTube
now your carb may not be identical to the one in the videos, but the principle is the same. DO NOT USE A DRILL LIKE THE VIDEO SHOWS ON THE SCREWS.
as you can tell when you pull up the videos, there are many videos to choose from. these two will help you out quite a bit. but pick the ones you want to use. they're all about the same. some give more details than others. holler back at us!
Old May 23, 2012 | 10:47 PM
Hey thanks! I'll do that but do you know how to take off the plastics..? Because they are the little snap on ones and I don't want to break them..? Thanks!
Old May 23, 2012 | 11:01 PM
Jaster94's Avatar
i've never messed with that particular style. are they the squeeze/remove molly style rivets or the push through shirt button style? hmm....i just don't know. most of the time, most plastics are held on with a few bolts/nuts and some style of plastic molly/rivet style fasteners. that's all i know. sorry.
Old Dec 16, 2015 | 02:08 PM
Ek9man's Avatar
Default 2007 kawasaki kfx 90a wiring schematic diagram?
Just recently purchased a 07 kfx 90 and a couple of wires are just hanging cut loose as well as a wire that come from the starter red with white stripe and a solid red I'm assuming that's 12v from the battery. I was wondering if anybody has a schematic of the wire harness for this model atv. Or know where I can find one. Or somebody who has one like it that can guide me through my struggle. Thanks in advance.
Old Dec 17, 2015 | 07:32 AM
LT80's Avatar
LT80 Expert
You need to start another thread.
Your question has nothing to do with this 3 year old thread.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
Sjrpp
Jul 5, 2015 09:04 PM
