Question about suzuki LTA 50
Old Jun 6, 2012 | 03:09 PM
LT80's Avatar
LT80 Expert
[QUOTE=eleven;3118651]I got a helmet with the quad thats why i said i dont need a helmet, who would let there child go on a quad without a helmet thats just nuts[/QUOTE
I appologize.
FYI: up on the choke is usually on.
"who would let there child go on a quad without a helmet thats just nuts"
I agree. It's just that we do get nuts in here.
I'm a lil sensitive when it comes to the helmet thing.
I hope the lil gal and you have loads of fun.
Old Jun 6, 2012 | 03:14 PM
eleven's Avatar
thanks for the reply also ment to say after the quad was runing for around half an hour i pushed the choke button down to see what it would do and it cut off, so put the choke back up and just left it there. Theres also a switch that say pri,off and pri again so two pri's and a off anyone know what this is for the switch has always been at off.
Old Jun 6, 2012 | 04:01 PM
desjardins2012's Avatar
dont know what the pri is but you shouldn't have to ride with the chole on
suprised your not flooding out after awhile
Old Jun 6, 2012 | 06:10 PM
  #15
eleven's Avatar
I think the chokes off when its at the top its a suzuki lta-50 i have, been trying to look of the net for info but theres nothing its all for the older lt-50
Old Jun 6, 2012 | 07:33 PM
  #16
LT80's Avatar
LT80 Expert
Petcock::
It's vaccum operated. Off is on, once the motor creats vaccum. The vaccum opens a dighram and lets the fuel flow.
Pri is prime. It's to fill the carb after being empty. Lets say you clean the carb (and I think you should) the carb will be dry. You would put the petcock on prime to fill the carb then put it back to the off position.
I've never seen a "push down" choke but I can be wrong.
I think it's running with the choke on which points to a good carb cleaning.
Old Jun 7, 2012 | 02:28 AM
  #17
eleven's Avatar
thanks for the reply, is cleaning the carb a job i could do myself or should i take it to a garage ?
Old Jun 7, 2012 | 04:45 AM
  #18
Alexlt50's Avatar
Could do it yourself no problem if your handy with a screwdriver, take photos as u could cant really go wrong
Alex
Old Jun 8, 2012 | 09:10 AM
  #19
eleven's Avatar
just found out up means the choke is off on the lta also how do you tell if theres a restrictor on the quad i know about the screw that you turn to slow it down, but is there another one somewere on the quad its quite slow going up hills.Also i'm going to clean it with a jet wash this weekend should i do anything after i clean it like spray the chain or wheels with anything ?
Old Jun 8, 2012 | 12:46 PM
  #20
LT80's Avatar
LT80 Expert
Up is off..Well slap me and call me Sally..
*note to self* up is off on a lta50*
LOL
