2000 lt80 weak spark
Old Jul 2, 2012 | 08:48 PM
jyoung111's Avatar
Default 2000 lt80 weak spark
Hello, my problem is I have weak spark...i.e. I can hold the spark plug between my fingers as it fires. If I hold the plug against the engine case, it will not jump the gap. I have been through these forums over and over, and checked a number of things...the stator I sanded and cleaned...it reads 180 ohms, and I have 30v to the cdi. The cdi is brand new. I have 16 ohms from the spark plug connector to negative terminal on coil. The plug is a new ngk. Compression is about 120 psi. Also , the engine ground is good. I am at a loss. I just picked this up for my 6 year old son, but thus far it remains idle. I suspect maybe the coil is bad...but really not sure...I am getting weak spark and the 16 ohms sounds about right. Any help would be greatly appreciated. Not sure if this helps, but the resistance spade to spade on coil is 0 and the resistance from input spade to plug connector is 16 also. Thanks again.
Old Jul 3, 2012 | 08:12 AM
LT80's Avatar
LT80 Expert
Welcome to the forums.
I'm thinking CDI/coil.
Better ask Lynn Edwards.
Old Jul 3, 2012 | 09:09 AM
jyoung111's Avatar
Default Thanks
LT80 thanks for your reply and thanks for all your help to me and others through other posts over the years. I was thinking it may be the coil. The cdi is a brand new Suzuki part, so I am really hoping it is good. How might I contact Lynn Edwards?
Old Jul 3, 2012 | 09:24 AM
jyoung111's Avatar
Default Found Lynn
I found Lynn E. and have sent her a message. Thanks for the tip
Old Jul 3, 2012 | 09:29 AM
LT80's Avatar
LT80 Expert
I think Lynn may be a guy...
To be honest, I never gave it any thought that it could be a gal.
LMAO!
Old Aug 10, 2012 | 12:04 PM
gree's Avatar
i have a brand new battery,switch and relay but i can only hear a click sound and wont start. as try to push start it i can hear the engine roll so i know the engine is not locked up. someone please help me. when i put the positive wire directly on the starter nothing happens. help.
Old Aug 12, 2012 | 09:30 AM
jyoung111's Avatar
Spark issue solved. Aftermarket. Kill switch was not wired correctly and/or faulty. Picked up used original off eBay, spark is now good. Aftermarket kill switch had green/yellow wire from cdi to ground. Also, it is possible that red/black from stator to kill switch was grounded if switch was faulty.
Old Aug 12, 2012 | 09:32 AM
jyoung111's Avatar
Gree , might want to check brake switch. It will not start if circuit is not made.
Old Aug 12, 2012 | 11:13 AM
LT80's Avatar
LT80 Expert
The tether should have been:: There is usually a metal end, that wire to ground. Other wire to red/black wire under the hood.
Yup..The brake switch circiut needs to be made to start it. I was never interested in the safety aspect of the foot brake switch so I took them off and twisted the wires together.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
jldominic
Honda Side by Sides
Aug 8, 2015 06:54 PM
suzukiquadrunner1987
Aug 6, 2015 03:59 PM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
