50cc eton lightning
Old Jul 21, 2012 | 03:02 PM
mmasini's Avatar
Exclamation 50cc eton lightning
ok so i bought a 50cc eton lightning and i was told it had no spark so i am looking at it today and well it has no battery and no starter and well no spark to. so i am trying to kick start it and i have the plug out and no spark. i am at wits end on this. i have tried with the key on and no spark. what can i do?
Old Jul 21, 2012 | 10:14 PM
Jaster94's Avatar
engage the brake. make sure the brake switch is working. this should satisfy the safety interlock. make sure your key is on and the rear tether, if applicable, is working and not killing he spark.
Old Jul 21, 2012 | 10:48 PM
LT80's Avatar
LT80 Expert
Welcome to the forums.
You may need a ohm tester (multi tester at sears about 15 bucks) and check out the switchs/connections Jaster mentioned.
You can also ohm the stator and cdi to see if they are working. Sorry I don't know the correct readings.
Also, make sure the motor is grounded to the frame. If in doubt, make a wire.
firsttimerider
Sep 20, 2015 09:07 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
Elkaholic
Sep 6, 2015 02:44 PM
