Lt80 won't start after head shaved 30 thou
Old 09-12-2012, 07:50 AM
Gsi-mark's Avatar
Default Lt80 won't start after head shaved 30 thou
As above just won't start don't no what's up with it
Old 09-12-2012, 07:59 AM
DAMONSQUAD's Avatar
whats the symptoms? is it cranking normal? no odd noises or anything hitting? are you sure the head was never decked before you did it? it could be completely unrelated to the head, but theres not enough info to go by, is it cranking slowly due to compression and a low battery? maybe the spark plug boot is loose on the wire?
Old 09-12-2012, 08:05 AM
Gsi-mark's Avatar
Cranking normal just seems like not firing up
Old 09-12-2012, 08:08 AM
Gsi-mark's Avatar
Checked cap that's ok sounds like its nearly wanting to start with choke
Old 09-12-2012, 08:51 AM
LT80's Avatar
LT80 Expert
Wet plug?
Sounds like it's flooded.
OR......no fuel...hand choke it w/2 fingers in front of the carb.
There is no reason for the shaved head to cause a no start condition.
Old 09-12-2012, 09:01 AM
Gsi-mark's Avatar
No wet plug can it be no fuel?
Old 09-12-2012, 10:02 AM
LT80's Avatar
LT80 Expert
Yes, hand choke it and see if it goes.
Old 09-12-2012, 10:15 AM
jskinn's Avatar
Probably a dumb question but did u adjust valves? Taking off 30 thousands will change valve geometry alot.
Old 09-12-2012, 10:17 AM
DAMONSQUAD's Avatar
2 stroke=no valves
Old 09-12-2012, 10:20 AM
Gsi-mark's Avatar
Hand choke explain pls
Quick Reply: Lt80 won't start after head shaved 30 thou
