help with alpha sport LG 90
I have a 2001 alpha sport LG 90 will only run with hand over carb did a compression test and it was 60 psi i am sure it should be higher so i have a few questions.
I am looking at buying a top end kit
1 what should the compression be on a 90 cc 2 stroke?
2 from what i have been told the alpha sport is the same as a polaris scrambler and parts should work on my alpha sport.
3 dose anyone know where to get a service / repair manual for it ?
thanks for any help i can get
well i pulled the piston out the rings looked good , the piston had carbon build up on the top and the jug had a dark spot about 1/2 in wide and a 1in long. there was alot of oil around the exhust gasket and pipe where it bolts to the jug . so i dont think the compression loss was from the rings.
dose anyone have any sugestions on what i should do or what to do next
thanks
thanks
09-30-2015 01:37 AM
