Lt80 struggling to pull uphill
Old Nov 5, 2012 | 02:45 PM
Gsi-mark's Avatar
Default Lt80 struggling to pull uphill
Could clutch be on its way it's fine on flat ground
Old Nov 5, 2012 | 05:36 PM
LT80's Avatar
LT80 Expert
Clutch or compression. A plugged pipe can do it too till it plugs worse.
Old Nov 6, 2012 | 01:41 AM
Gsi-mark's Avatar
Any other ideas just loses power up steep hills might be because I've been riding it weigh 200 pounds
Old Nov 6, 2012 | 08:08 AM
LT80's Avatar
LT80 Expert
So you've checked the clutchs and compression?
IMO 200 pounds isn't a big problem.
I suspect a roller problem but I'd check the compression.
Old Nov 6, 2012 | 08:30 AM
Gsi-mark's Avatar
Will check roller as I'm removing two next week seems to be running fine today if it get wet can belt slip
Old Nov 6, 2012 | 05:06 PM
Brian Adwell's Avatar
Yes,belt will slip if it gets wet.
Old Nov 7, 2012 | 12:15 AM
LT80's Avatar
LT80 Expert
After knowing that (water), I think that after clutch maintenance, all will be fine.
Old Nov 7, 2012 | 03:56 AM
Gsi-mark's Avatar
Yes it got wet on Sunday I bet that's the prob as it seems ok now
Old Nov 7, 2012 | 06:05 AM
DAMONSQUAD's Avatar
probably a wet belt, i removed my oil injection pump once and never plugged the hole, and water got into the hole where the pump goes, it was wet FOREVER lol, i figured it would dry out after a few days, but nope, had to disassemble and dry everything and clean it all. now i cover the pump hole
SDR-II
Sep 29, 2015 01:06 AM
bigred20653
Aug 31, 2015 12:41 PM
Bergmann
Aug 13, 2015 03:51 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
