Lt80 massive problems
Old Nov 23, 2012 | 06:19 AM
Gsi-mark's Avatar
Default Lt80 massive problems
Ok clutch mod 2 rollers removed put back together no top end speed sounds like droning noise wen slowing down
Old Nov 23, 2012 | 08:03 AM
LT80's Avatar
LT80 Expert
Removing 2 rollers does effect top speed. Try 5 or 6 rollers.
Old Nov 24, 2012 | 09:01 AM
Brian Adwell's Avatar
Have you lightned rear shoes?
Old Nov 24, 2012 | 09:46 AM
Gsi-mark's Avatar
Yes mate I have
Old Nov 24, 2012 | 10:40 AM
LT80's Avatar
LT80 Expert
The rear shoes can make a lil clicking noise when modded.
Rule of thunb:: if you don't think it's right, take it apart again and re-assemble.
Old Nov 24, 2012 | 10:46 AM
Gsi-mark's Avatar
When revved it stops just tickover
Old Nov 24, 2012 | 12:41 PM
YZOtis's Avatar
^^^^^ Take it apart & check the rollers ^^^^^
Old Nov 25, 2012 | 07:59 AM
Gsi-mark's Avatar
The variator with rollers in seems loose on spindle could of I missed a washer out any pics of the assy
Old Nov 25, 2012 | 11:34 AM
YZOtis's Avatar
The notch on the movable drive face plate must fit the key on the crank shaft. If you missaligned the key and tightened the back of the drive plate to the front of the key it will probably be loose now with the back of the drive plate chewed up ... Where the rollers in the correct position?
Old Nov 25, 2012 | 01:07 PM
LT80's Avatar
LT80 Expert
That fiche don't show the big washer that goes between #8 and #10 (89 and newer)
