E-Ton Viper 90 (old) Hard Starting and low torque
Old Feb 1, 2013 | 05:18 PM
JohnSawyer's Avatar
Default E-Ton Viper 90 (old) Hard Starting and low torque
I have an older Viper 90 that has been a workhorse for some time. My kids are starting to outgrow it, but it's still a fun, well built machine.
It seems every other season I need to tear down the carb, and I've done that, but now it is really hard to start when it's cold... Even if it ran 2 hours before...
I did the usual: Air filter, fuel filter, drained carb, etc. It takes a quick shot of starting fluid to get running, and seems to run weak... This is new. . . (ok, it runs ok on flat ground, but won't pull the kids up even a little hill)
I might be tracking multiple issues here... not sure...
Any help or advice would be great.
John
Old Feb 1, 2013 | 05:27 PM
JohnSawyer's Avatar
Oh, it has a manual choke... which is working...
Old Feb 1, 2013 | 06:17 PM
Jaster94's Avatar
use a compression gauge and see what you've got. please don't do the thumb trick. that'll only tell ya that you got "some" compression. get a gauge so you can be accurate. it's like this: do you use a voltmeter/ohm meter to check out wiring/circuits or do you use something homemade to check out wiring? yeah, go with the correct tools. it's an investment in your toys.
Old Feb 1, 2013 | 07:17 PM
LT80's Avatar
LT80 Expert
Yup, compression.
Old Feb 1, 2013 | 10:41 PM
JohnSawyer's Avatar
Good point. If it's compression . . . I'll just sell it cheap... given we bought a 200 to replace it... I'll get a gauge tomorrow. What's the compression supposed to be?
Old Feb 1, 2013 | 11:23 PM
LT80's Avatar
LT80 Expert
90 minimum.
Old Feb 2, 2013 | 12:58 AM
JohnSawyer's Avatar
Thanks. If it is low i'll send the wife to the shop for a "can of compression"
Old Feb 2, 2013 | 10:31 AM
Jaster94's Avatar
lemme guess,,,,that's right near the sky hook and the can of whoop'em, right?
Old Feb 2, 2013 | 10:39 AM
LT80's Avatar
LT80 Expert
I had a eton in that the exhaust screen was full of goo and wouldn't run.
MikeyBoyesq
Nov 27, 2020 02:44 PM
chinkapin
Jul 14, 2016 06:58 AM
VRRRRT
Jun 27, 2015 09:38 AM
Fnqrider
May 31, 2015 08:29 AM
1000gade
May 27, 2015 12:37 PM
