Another LT50 starting problem
Old Feb 5, 2013 | 04:54 AM
Alexlt50's Avatar
Default Another LT50 starting problem
Hi
I got another LT50 a few days ago, I didn't hear it running when I got it as it had been laying a while and wanted to change the fuel etc before trying
I cleaned the carb, new plug, compression is at 80psi which I've read is OK for one of these
It will start with easy start but I don't like using that stuff
Any ideas? Cheers
Old Feb 5, 2013 | 08:05 AM
LT80's Avatar
LT80 Expert
I don't consider 80 comp good.
Old Feb 5, 2013 | 08:14 AM
Alexlt50's Avatar
I was reading the gauge wrong sorry its at 120psi I was looking at bar lol
Old Feb 5, 2013 | 09:42 AM
Alexlt50's Avatar
Turns out the left crankcase is away smoke coming from the pullstart rope hole
Rip
Old Feb 5, 2013 | 06:08 PM
Alexlt50's Avatar
Is it possible to change the seal without splitting the crankcase?
Thanks
Old Feb 6, 2013 | 12:13 AM
LT80's Avatar
LT80 Expert
Yes. The seals are on the outside of the case.
Usually under the clutch and flywheel.
Pry them out and tap them in.
I apply a film of grease on the seals.
Old Feb 6, 2013 | 04:00 AM
Alexlt50's Avatar
Thanks, for the price of them I may aswell see of this problem sorts it, I have the symptoms of LH seal leaking with the smoke from the pullstart area
Ill let u know how I get on thanks
Old Feb 6, 2013 | 06:11 PM
Alexlt50's Avatar
Well I found the problem or A problem at least the crank seal was hanging on the shaft completely out its hole, will need to see if a new one makes a difference
Thanks
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
