Dinli 50cc flooding ?
Old Feb 11, 2013 | 01:21 PM
my996duc1's Avatar
Question Dinli 50cc flooding ?
My neighbor brought over his Dinli Dino 50cc 2 stroke atv for me to fix and I am having some problems getting it figured out.
I can get it to start on starting fluid with the carb off but with the carb on it floods the cylinder almost immediately with fuel and will not start. If I air/dry out the cylinder I can get it to start again with starting fluid. I was advised that a new carb would solve my problem so I purchased one but, while it couldn't hurt to have a new carb, it did not solve my problem.
Do you have any suggestions on why the cylinder is flooding with fuel and what I should be checking ?
Is there a way to disable the electronic choke to try and start it without it ?
I am not sure how the electronic choke works or can I test it to ensure it is working correctly ?
I am also unsure if the new carb comes preset or do you have the starting settings that I should set it too ?
I should also state, I tried checking the float and it appears to be working properly. When I manual put a small amoutn of air pressure in the fuel in hose if I lift the float it will shut off the air. So I think the float is working properly.
I appreciate your help and any suggestions you have for getting this atv running again.
Thank you.
Old Feb 11, 2013 | 08:41 PM
LT80's Avatar
LT80 Expert
I recommend that you call/email Maximumrpm.com.
Justin was the original importer of the dinli and I'm sure the fine ppl there can help you.
Old Feb 12, 2013 | 08:55 AM
my996duc1's Avatar
while he has been helpful with his suggestions, his ideas for fixing it has not helped the problem.
_
Customer Service #1
May 15, 2020 08:46 AM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
firsttimerider
Sep 20, 2015 09:07 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Jaymc
Sep 11, 2015 07:45 AM
