lt 80 doesnt roll freely
Old May 19, 2013 | 04:15 PM
mditaz's Avatar
Default lt 80 doesnt roll freely
I have a 2005 lt 80 and when I push it it is very hard to push I thought the brakes where sticking but they are not so I took off the pull start cover and it seems that the belt is stuck or the clutch is not free wheeling any help would be great thanks in advance
Old May 19, 2013 | 10:48 PM
LT80's Avatar
LT80 Expert
Welcome to the forums.
I'd start by removing the front sprocket (you can use a small screwdriver and carefully pry the clip off) and see if it rolls better. It may the chain.
If not, you're into the clutchs to see what's going on.
Old May 20, 2013 | 04:34 AM
mditaz's Avatar
I took the chain off and it rolls fine so I think it must be in the clutchs is there some thing I should be looking for don't know much about them
Also I drained the tranny and white fluid came out this cant be right what do I want to put back in and what is the easy way to get it in the little hole on top
Old May 20, 2013 | 08:36 AM
LT80's Avatar
LT80 Expert
If it rolls with the chain off, it's the chain.
You use 80/90wt gear oil. It's slow going filling it.
Old May 20, 2013 | 11:40 AM
mditaz's Avatar
The chain is fine Should the front sprocket turn freely with the chain off It does not it turns really hard And when I turn the engine over that small front sprocket turns I don't believe it should I think It should spin freely
Old May 20, 2013 | 02:16 PM
LT80's Avatar
LT80 Expert
OK. Your prolly right on that.
Welp, your into the clutchs to see what's wrong.
Look for flat washers in the front. Bad bearings/sliding face stuck on the rear.
Old May 20, 2013 | 05:02 PM
mditaz's Avatar
do you have a fiche or a link or something of this so I have an idea of what to take apart
Old May 20, 2013 | 08:28 PM
LT80's Avatar
LT80 Expert
Ohio Motorcycle ATV Dealer - North Ridge Yamaha Suzuki - Geneva, OH - Scooter Utility-vehicle, snowmobile
You can look at a fiche there.
Remove all 4 footpeg bolts. Disconnect the plastic from the footpegs.
Lean it on the right side. Remove the rear tire.
Remove the bolts around the clutch cover AND the lil cover bolt at the 3 o'clock position
5mm allen and 8mm for the starter bolts and the pull start cover bolt.That'll get the clutch cover off.
17mm to get the clutchs off. You'll need a impact wrench for that.
Old May 24, 2013 | 05:29 PM
mditaz's Avatar
What type of clutch lube should I use
Old May 24, 2013 | 06:36 PM
LT80's Avatar
LT80 Expert
A dab of grease on each roller to hold them in place durring installation.
fd24
Jan 16, 2019 08:59 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Coondoog
Technical and How-To Articles
Sep 9, 2015 01:51 PM
Albertaboyy
Sep 9, 2015 09:51 AM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
