06 LT80 stumbles low n high
Old Sep 1, 2013 | 09:53 PM
swat2380's Avatar
Default 06 LT80 stumbles low n high
Our new to us LT 80 delveloped a problem today. At low throttle it stumbles and full throttle it stumbles. I pulled the carb apart cleaned out all the passages and jets, clutch feel fine and it pretty clean. I changed the air filter, transmission fluid with 10w40 and greased the zerk in back. Acts kinda like a vacuum leak or reed problem but I dunno. Ran great last time out. After a short run it will surge at idle n die. Any suggestions????
Old Sep 2, 2013 | 08:49 PM
swat2380's Avatar
Found the problem n running well. I disconnected the oil injection while I was at it.
Old Sep 10, 2013 | 08:32 PM
yamaha_2000r6's Avatar
What turned out to be your issue? I'm having a similar problem
Old Sep 11, 2013 | 12:07 AM
swat2380's Avatar
I had the needle/jet moving up and down with the slide on the carb. I ran the needle or jet as its called thru the top of the slide washer/throttle cable retainer instead of underneath it.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
fredrikrosen
Sep 28, 2015 09:58 PM
r1pilot83
Sep 27, 2015 07:38 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
