head light and tail lamp ltz 50
Old Oct 18, 2014 | 01:51 AM
50mile's Avatar
Default head light and tail lamp ltz 50
has any one installed a head light or tail light on a Suzuki ltz 50.with electric start, must have a charging coil.probally no lighting coil.with the low amp/watt led lights available 12 volt,i may try something.any ideas or suggestions.would be more for safety, but may alow grandkids to ride a little later.
Old Oct 18, 2014 | 07:52 AM
LT80's Avatar
LT80 Expert
Welcome to the forums.
Others have fashioned led's on before like you're thinking.
Old Oct 19, 2014 | 07:36 AM
beyondupnorth's Avatar
One 10 watt led makes a pretty good headlight. I tried 2 one my polaris 90 and everything looked good. One it handled no problem no voltage drop at idle, the second pulled the voltage down at a idle but would have been fine riding and I still had the stock taillight bulb.
That is until I hit the start button and burnt both lights out. You may want to find a fuse that is just big enough to run the lights and install one on both the hot and ground to the lights.
Not sure but believe I have a minor ground problem that caused this and the battery neg used the light as another path to transfer its current to the frame.
I just had the light grounded to the batt as a convenient place while I check the voltage. Probably a bad idea in hindsight.
I"m still thinking of doing this again but was wanting to kick it around on a forum to see if I can find where I went wrong for sure. Sucks to fry those lights, although they are getting cheaper..
I know the 2 10 watt leds I added to my 660 Griz make a very noticable difference in the forward lighting. I know many guys put 10X this on the front but really thats overkill imo.
sweaver
11
Aug 18, 2015 03:47 PM
Bulgin88
Aug 1, 2015 06:39 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
ranvette
Jul 4, 2015 06:13 PM
