gas cutoff valve
Old Mar 2, 2018 | 04:15 PM
yettie's Avatar
Default gas cutoff valve
110cc coolstar
wont start. someone says its the carburator. I cant find the gas shutoff valve. need help
Old Mar 3, 2018 | 02:59 AM
Don't know the Coolster, but all bikes have a fat pipe running from side of carb to underside of fuel tank. Some have a tap under the tank, some a tap on the carburettor (very stupid idea), and some no tap at all. With the latter types a set of vice grips on the pipe to crimp it off while you work on the carb may do the trick, or you can run the pipe into a can, once removed at the carb end, to drain the tank.
rodehardputawaywet
Jan 16, 2017 03:07 PM
BroncoBilli
Nov 14, 2016 01:47 AM
abburns
Sep 2, 2016 08:06 PM
BradOwens
Jul 24, 2016 10:37 AM
