Having trouble with my 1985 Suzuki LT 50cc 4-wheeler put a new top-end on it got it s
Old May 20, 2018 | 07:04 PM
Brye's Avatar
Default Having trouble with my 1985 Suzuki LT 50cc 4-wheeler put a new top-end on it got it s
  1. I've got a 1985 Suzuki LT 50cc four wheeler put a new top-end on it got it started wrote it up the road and then it bogged out on me when it start back got it back home there is sludge on the piston I cleaned it all up again put everything back together is trying to start it's got spark it's getting fuel I did a compression test on it it's only getting 50 psi what can I do
Old May 20, 2018 | 07:10 PM
Brye's Avatar
  1. I did notice when I took it back a part after it got sludge on the Piston that one of the piston rings was a little bent I got it back in the line or it's supposed to be there's a little bit of oil and gas on the Piston little bit and is trying to fire but it won't I've tried putting starter fluid in it and it tries even more to start but it won't
Old May 21, 2018 | 07:41 AM
LT80's Avatar
LT80 Expert
Don't really matter. That cylinder needs bored to the next size up piston.
No reason to even try at 50 lbs comp.
Old May 21, 2018 | 08:21 AM
DirtDevil101's Avatar
SuziOzark
Apr 20, 2009 06:03 PM
mountainmanup
Aug 4, 2005 09:26 AM
KMDuner
Jan 16, 2003 06:18 PM
94DGblaster
Jul 8, 2000 09:52 AM
