LT-A50/KFX50 top end replacement difficulty?
Old Oct 29, 2018 | 11:30 AM
untraceable's Avatar
Zipped up to a guys shop and he took off .035. Not warped anymore!
Old Oct 29, 2018 | 11:33 AM
Old Oct 29, 2018 | 02:57 PM
LT80's Avatar
LT80 Expert
If your plumbing snake can heat that pipe up cherry red, go for it.
Old Oct 30, 2018 | 08:39 PM
Got the head put on. Had to order a gasket kit for a JR50 as the “KFX “ was out of stock. Lol
I cycled it around 2x to make sure the piston wasn’t going to touch the plug, then bam, first pull it lit right up. Blipped the throttle a couple times and it certainly seemed zippier. Even sounded better. Tomorrow I may have a chance to take a spin before I get the kid from daycare.
Will take a look at the spark arrestor/exhaust insert in the muffler when I get a chance too.
Old Nov 1, 2018 | 05:35 AM
  #15
after the head work and removed the spark arrestor. Played around with which set up felt best with the silencer core/cap removed ect. Think it felt strongest with the guts out. Will try to burn out the pipe Friday
Old Nov 2, 2018 | 11:40 AM
  #16
little before and after. Pretty clear how quick it hits top rpm and higher revs too
Old Nov 2, 2018 | 04:01 PM
  #17
LT80's Avatar
LT80 Expert
Cool
Old Nov 9, 2018 | 06:45 AM
  #18
Do you think over oiling from the injection system can cause tough starting cold? I’ve been running the quad a lot with the rear end in the air which lets the axle spin freely pumping oil like crazy where as if I had it on the ground, the oil mix would be greatly reduced. Quad runs great, easy to start warm, but after sitting a week, it’s brutal.
i just filled the oil tank with Amsoil Dominator when I got it, I was hoping to make it through the tank before switching to premix. I guess no harm in transferring the tank oil back into the bottle
jmr
Sep 26, 2016 08:16 AM
Barrera90504
Dec 8, 2014 10:04 AM
WAATV
Mar 21, 2010 09:37 AM
WAATV
Sep 2, 2008 03:44 PM
turfboy76
Dec 31, 2003 12:06 PM
