Power loss
Old 05-02-2020, 10:33 AM
fordrulz's Avatar
Default Power loss
Hi guys. I have a 2001 scrambler 90CC that seems to lose power when you give it throttle at idols good and will run good if you restrict the air intake if you leave it alone and you give a throttle it bogs out and will eventually stall. I've cleaned the carb I've replaced the carb tried all the adjustments I can and it seems like the air adjustment screw needs to go in another turn after its bottom out. Fuel is clean filter is new. Anyone else ever had this issue? not sure what's going I appreciate any help thank you
lonerider856
10-29-2015 08:17 PM
ozarkeun
08-05-2009 12:54 PM
CALEBANDJENNA
ATC 3-Wheelers
08-08-2008 06:48 AM
hotlicks
10-30-2005 11:56 AM
2480
08-29-2005 02:02 PM
Quick Reply: Power loss
