Eton 90cc
Old Aug 12, 2022 | 02:09 PM
Sadie123's Avatar
Default Eton 90cc
Hello I’m new here.
So I’ve just spent close to a thousand dollars to try and fix my sons atv and no luck.
I can get it to start but when I go to give it throttle it stalls out every time.
Old Aug 13, 2022 | 02:01 AM
Some, maybe all, Eton 90s were two strokes so the exhaust could be blocked. Worth checking for that if it is a 2 stroke. The most common cause of the engine stalling when you rev up, is carb partly blocked, but I assume you have cleaned it or fitted a new one. New doesn't always work though, as you may have to set carb jets or even fit different ones, to get the engine running properly. Does the bike roll OK? If brakes are sticking, the engine may not have the grunt to overcome this when taking up the drive, same goes for faults in the drive train, variator or gearbox problems. $1000 seems an awful lot to have spent without result. I guess you could have bought a good used Eton 90 for less.
grapejuice420
Jun 29, 2016 06:30 PM
capebreton1967
Apr 12, 2011 07:23 AM
glassman181
Feb 12, 2007 06:00 PM
