smoking cannibal
Old Jun 28, 2004 | 12:08 AM
racer21's Avatar
Default smoking cannibal
About the time cannondale went out of business I bought a brand new 2002 cannibal for $4,500, and only put about ten hours on it. It started smoking bad, cutting out and backfireing and finally wouldnt even run. My dealer found that the cylinder was ege shaped, so he put an after market cylinder, new piston and rings in it. When i got it back It ran good for about 5 hrs. started smoking bad and fouled two plugs. when the smoking occured it didnt really want to start either when cold. After burning the plug twice it smoked quite a bit and cleared up after a while, and now seems to run fine again. (there wasnt mixed gas in it) now it also starts fine.
could anyone please help me?
Old Jun 28, 2004 | 02:36 AM
Cannibalq8's Avatar
what is the color of the smoke? its seems that oil went inside cylinder and cause that smoke ( burn oil ) . do u make this updates :-
1- oil hose breather
2- stage 8 bolts
i recommend not use it to prevent a possible hydrolocking. make sure u make all the necessary updates. check the updates here http://www.cannondaleriders.com/tech/index.shtml
BTW... what is that aftermarket cylinder?
Old Jun 28, 2004 | 09:43 PM
racer21's Avatar
I wrote the original message,
it was blowing blue smoke (oil smoke). A couple drips of oil came out of the pipe. It cleared up after a while and now its running good.
Old Jun 29, 2004 | 12:30 AM
armoks's Avatar
HMM you seem to have hit the famous hydro lock. The check ball for the oil line seems to stick after setting for a while and all the oil drains from the spars into the motor. Seems you caught it before it filled your cylender and locked up your piston. It usally doesn't do damage you just will have alot of smoke for a little bit. Check your filter regualry and see if you are getting excessive amounts of metal floating around, sometimes it will stick in that check ball and keep it open.
Check out cannondaleriders for some more detailed info on the subject!
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
EIF
Apr 20, 2017 07:15 PM
CosmoM
Sep 21, 2015 04:57 PM
bvolks
Sep 13, 2015 12:57 PM
