electrical troubles
Old Jan 31, 2005 | 02:45 PM
Moto440's Avatar
Default electrical troubles
i have an 03 moto 440 and its wont charge the battery, weird the battery is good but even when riding it loses charge and then wont restart i dont know what the deal is, voltage regulator, etc?? any help would be appreciated!!
Old Jan 31, 2005 | 08:37 PM
WISTECH's Avatar
First disconnect the plug to the stator. Check for continuity between all 3 terminals of the wires going to the stator.. They should all have low resistance between each other. Then connect connect one lead of your ohm meter to a good ground and test all 3 terminals of the same plug you just tested . There should be infinite or extremely high resistance. If the stator is grounded you will need to pull the flywheel and check the wires for a short to ground on that small retainer that the wires go through under the left side of the flywheel. It might have worn through the wires and shorted out the stator. Its very common and the update is to repair the wires and put a little extra wrap around them. let me know what you find and we will go from there.
Old Feb 1, 2005 | 09:41 AM
Moto440's Avatar
greati am hoping to put some time into it this weekend as the snow is melting here so the snowmobile is taking up all my time!! will let you know what i find out
Old Feb 14, 2005 | 09:12 AM
Moto440's Avatar
finally got my chance to look at it, the continuity was good between all pins no matter what way i put them on the meter, also when i checked for a short to ground and tried each of the three pins to the engine and neg battery terminal just to be sure and all were OL out of limits. so that seems to be good what else could it be??
i also noticed on the right side of the quad on the frame under the fender by where that connector was i saw to holes in the frame like something was supposed to be bolted there? any idea what is supposed to be there if anything, if you need i can take a picture, thanks
95wolv
Sep 27, 2024 12:00 PM
ReconBayou
Oct 31, 2022 05:37 PM
mrtidy
Feb 3, 2016 05:00 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Clint Russell
Sep 25, 2015 03:20 PM
