can't find the swelling O Ring in the gas line!!
Old Apr 18, 2002 | 08:37 PM
mynewcannondale's Avatar
Where is it?
Old Apr 18, 2002 | 08:39 PM
special's Avatar
Look at the end of the gas line that plugs in to the quick connects.
Old Apr 18, 2002 | 08:42 PM
from the of the gas tank those quick connects or different ones
Old Apr 18, 2002 | 08:43 PM
briansgi's Avatar
It's on the inside of the female connector, go to:
http://www.rsperformance.net/
and click on tech tips, scroll down and they show a closeup of the connector, it's inside that connector.
Old Apr 18, 2002 | 09:03 PM
how in the hell are you supposed to be able to tell if it has swelled or not. how do you fix it? I did notice my fuel pump making noises last week before the stalling started. By the way it only stalles if im going up a slight uphill and tapping the trottle "tap, tap, tap" you get the point when I do that it dies hard and fast. Thanks for the quick replies fellas.
Old Apr 18, 2002 | 09:10 PM
briansgi's Avatar
Just pry it out and go to an auto parts and match it up and replace it. I just looked at the parts illustration and it shows the female connector but it doesn't show the o-ring or a part number. Not sure why!
Old Apr 18, 2002 | 10:03 PM
4strokemadman's Avatar
Mynewcannondale,
Have you replaced the fuel filter? Usually if the pump is making noise the first thing to check is the fuel filter. Also make sure both lines to the tank are connected. I haven't heard of that many swelling O-rings. Most of the time people that have this problem are running race fuel.
Old Apr 18, 2002 | 10:09 PM
YoDaddy's Avatar
Old Apr 18, 2002 | 10:16 PM
It really depends on the engine. An efficient combustion chamber design is key to running high compression ratios on pump gas. With the Cannondale 92 Octane pump gas is fine. On the Cannondales depending on what race fuel you use you could actually lose HP. Some race fuels require a new map.
ghost civic
Jul 27, 2015 03:15 AM
southbayman
Jul 24, 2015 09:30 AM
Aitch
Jul 21, 2015 09:40 PM
xbin87116
Jul 13, 2015 02:10 PM
clsharky
Jul 13, 2015 02:07 PM
