new bulletins
Old Jul 15, 2002 | 03:44 PM
jcv400ex's Avatar
http://www.cannondale.com/motorsport...f/TB02-008.pdf
and
http://www.cannondale.com/motorsport...f/SB02-012.pdf
New bulletins guys.
Old Jul 15, 2002 | 04:37 PM
briansgi's Avatar
I know there has been alot of discussion on this forum about battery issues, charging problems, etc. In bulletin 08, on page 4, it tells you what the battery voltage should be. At 3000 RPM, the voltage should be between 13.5 and 14.5 volts. I find it interesting the next bit of information it notes that extended idling can cause the battery voltage to drop!! That tells me the charging system is not quite as robust as it probably needs to be. All the more reason to keep trickle chargers on those batteries!!
Thanks for the heads up jvc440ex!
Captjay
Jul 23, 2015 12:33 PM
PilotNut
Sep 6, 2005 11:31 PM
husky100
Apr 29, 2005 06:54 PM
KNOWSALOT
Jan 21, 2003 04:41 PM
