Plug Fouling?
Old Sep 12, 2002 | 10:34 PM
JayBR's Avatar
How is this correct offset determined?
I read it's set on a dyno at the factory, are you saying it should be dropped after a few hours are on the engine?
Mine was set at .80 from the factory
Old Sep 12, 2002 | 11:10 PM
smitty911's Avatar
All the injectors have a slight differance in flow rate. High performance V-8 you can buy matched sets to ensure that all 8 are giving the same.
Now on to our quads. You have two injectors as they are used they break-in as well, and start to flow more fuel, but the ECU thinks it's giving X based on duration, now with it flowing more at the same duration you have a rich condition and it is possible to fuel the plugs. This is not a knows all end all, this is just what happens.
If you are running rich there are several ways to lean it out. Offset, pulse width, etc.
Smitty
Old Sep 12, 2002 | 11:34 PM
JayBR's Avatar
OK,
I remember someone telling me the offset had something to do with the difference in the the 2 injectors, and that the lower the number the closer they where matched.
Hankey Pankey
May 1, 2018 01:33 PM
Shainasmash
May 8, 2017 06:38 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
cornermike
Jul 30, 2015 06:37 AM
Captjay
Jul 23, 2015 12:33 PM
