crankcase stud update?
Old Feb 5, 2003 | 08:09 AM
OFFROADREDNECK's Avatar
Default crankcase stud update?
What do I need to do to check and see if my 03 le cannibal has this update? Does it involve bleeding the clutch or anything like that? Thanks.
Old Feb 5, 2003 | 12:28 PM
markvette's Avatar
there are 6 bolts that have to be changed. there is only 1 you can see without pullin the motor. take the clutch cover off, pull the clutch. the bolts behind the clutch should be a stud wit a nut on it. if it is an allen head bolt you need the update. yes you will have to bleed the clutch when you put it back together. you can go to cannondales web site to the bulletins and click on the crank case stud update. there are pictures showing you all six bolts and the locations
Old Feb 5, 2003 | 12:39 PM
Thanks. Ill probably just let my dealer check it for me. If they ever can do warrenty work again that is.
Do you have to pull the clutch to check even one of the bolts?
Old Feb 5, 2003 | 08:20 PM
mxmike's Avatar
HMMMMMMMMMMM.I changed my clutch plates and never had to bleed the clutch about 2 months ago.And this weekend I took the clutch plates and basket out and never had to bleed it.Both times I just re-adjusted it.Did I do something wrong or wright?
Old Feb 5, 2003 | 10:13 PM
markvette's Avatar
my bad, i thought you had to bleed it.
mike, kip is having pro action make that shock we busted the seal on a zero preload.
Old Feb 6, 2003 | 12:52 PM
CaliforniaCannibal's Avatar
Anybody know how much the crankcase stud update kit costs?
According to the tech bulletin, the part # is 913-5002552.
I just want to know how much the parts are, I'll install it myself.
Old Feb 6, 2003 | 04:01 PM
markvette's Avatar
if you can get it from cannondale it is free but the ones we ordered are on back order from them. i read on another thread here that quad source is selling them.
Old Feb 6, 2003 | 06:53 PM
faster440's Avatar
quadsource will have them by the end of next week 734-941-3484
Old Feb 6, 2003 | 07:11 PM
mxmike's Avatar
Mark I wasn't saying you were wrong.I realy don't know if you are suposed to bleed it or not.I was hoping someone that realy new for shure would chim in.
If you get the rear shock done are you going to get the front done to?Just wondering.It may not be a good idea to only get the rear done.It will squat in the rear and make it want to raise the front up real easy.Anyways I cant wait to see how it turns out.I would not mind getting my shocks converted to zps.It looks like it helps alot from what I have seen at the races.
Old Feb 9, 2003 | 12:31 AM
jschner's Avatar
I've heard that Cannondale is actually shipping out parts again. Just real slow with the lack of man-power.
On the stud update why is it the early engines have the allen bolts but less of a problem?
Scooter's Shop
Oct 9, 2015 02:09 PM
chewy78
Sep 8, 2015 10:37 AM
KSJOHN
Aug 30, 2015 08:15 AM
QuadCity
Aug 13, 2015 12:58 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
