HELP!
Old Feb 8, 2003 | 06:46 PM
DHP400ex's Avatar
Default HELP!
First ride on the Cannondale since the break-in..The problem is when it warms up and you putt around on it for a few, or let it just idle for a second then try to give it gas it feels like its loading up and wanting to foul the plug and die. As long as your running the heck out of it its fine. It still has the stock cannibal map and toaster on it. And i put a new plug in it and the old one looked fine except for a little black dry film....and the fuel filter looks fine also<<still the one on it from when i bought it...Any ideas? thanks
Old Feb 8, 2003 | 07:33 PM
onetouch8100scanner's Avatar
Default HELP!
1) check the octane of the gas.
2) did you changed the oil and the gear oil after the break-in?
Old Feb 8, 2003 | 07:59 PM
CANNIBAL440's Avatar
Default HELP!
Make sure the idle is set to 2100-2200rpms. If the idle is too low, these motors hesitate and, or stall alot. Also, almost every cannondale comes set too rich from the factory. Have your dealer lean it out if it is still acting funny after the idle adjustment. You can also do this yourself if you buy the D+M kit .
Old Feb 8, 2003 | 08:29 PM
DHP400ex's Avatar
Default HELP!
I changed Oils and checked idle(and set it up) but still same sluggish/foul/stall symptom. I put new fuel 93 octane in it and was wondering if i put on a slip-on would it help?
Old Feb 9, 2003 | 10:55 AM
DHP400ex's Avatar
Default HELP!
Anyone? Think since its only about 20 degrees outside that would be a factor in this?
Old Feb 9, 2003 | 11:15 AM
Ryanstones's Avatar
Default HELP!
I'm kinda hazy on the description of your problem. it starts fine? but it doesn't want to run off idle? Sounds like a fuel problem. replace the fuel filter, or at least confirm the quick connects are securely fastened.
Old Feb 9, 2003 | 03:04 PM
DHP400ex's Avatar
Default HELP!
I dont know what was wrong with it...Rode it today and it was in the upper 30's and it ran fine...Not a problem..who knows? Just wont ride it when its below freezing I guess.
Old Feb 9, 2003 | 08:58 PM
dawzie's Avatar
Default HELP!
I've been ice racing mine and have not had a problem. It's been between 15f and 35f the last 3 weekends and have not had one problem.
Old Feb 11, 2003 | 09:10 PM
UPSIDEDOWN's Avatar
Default HELP!
as with any engine, they run rich when cold. after the engine warms up,
rev the engine high to clear any unburned fuel from the cyllinder. i usally
take my cannindale for an aggressive ride for a minute or two.
i have a 2002 cannibal and the factory plug was too cold, so i changed it
to the 2001 spark plug.
Old Feb 11, 2003 | 09:18 PM
dubya1's Avatar
Default HELP!
DHP,
Change to an 8 plug, Verify your idle RPM, check your air filter....ie is it installed correctly?,,hose clamps on thottle body..........Its about 1 here right now and I have no problems.
Keep us informed
