Crankcase, Battery Tray, & Engine Mount Kits??
Ok I have a few questions.
1. Who makes the crankcase update kits? How much are they? Do you have to bleed the clutch to check for the update?
2. Can I do the Battery Tray update myself? If so what is involved?
3. Who make the engine mount update kits? Price? Am I right in understanding that if my engine says Cannondale on the side by the drain plug that I need the update?
Thanks, the website isnt much help.
Hey Kodiak
1. link
you don't have to bleed the clutch. Checking this is easy, and important. You probably don't need it.
2. Just add a couple washers between the tray and frame at the trays 2 rear bolts. this tips the tray forward a little to avoid the battery rubbing on the motor mounts.
3. so far only available from c'dale, you probably need this one, but i'm unclear as well on the identifier.
ride on man.
1. link
ride on man.
trx430ex
Oct 18, 2000 01:11 PM
