9:1 compression. Will it run on pump gas
Old May 3, 2000 | 09:10 AM
bigmanm's Avatar
I have a 9:1 compression wiseco piston. Can i run it on standard 87 octane pump gas without detination.
Old May 3, 2000 | 11:55 AM
boomer's Avatar
What do you ride? Anyways, that shouldnt be a problem. Mine was stock with 9.25:1 and it ran fine..no knocks. I now run 10.25:1 and run premium with no knocking. Havent tried the regular with it though.
Old May 3, 2000 | 12:41 PM
Tree Farmer's Avatar
Might, depending upon spark advance, load, valve timing, rpm, etc.
My suggestion; chance it! If pinging occurs, move up a grade or two.
Tree Farmer
Old May 3, 2000 | 01:43 PM
ScoobyDFW's Avatar
The DS650 has a 9.7:1 compression ratio and Bombardier recommends 91 octane pump gas. Gas prices should fall, so why not run 91-94 octane?
Old May 3, 2000 | 11:25 PM
Adam Zuroski's Avatar
The Kawasaki Mojave has an 11:1 compression ratio stock, I'm not sure what they recommend, but You should be fine.
Old May 4, 2000 | 05:40 PM
Mike Frey's Avatar
I prefer at least 92 in my 400EX. Sometimes, 92 or 93 isn't available, so I get 91, but one octance point shouldn't make a difference.
Old May 4, 2000 | 06:25 PM
JRM's Avatar
JRM
MY 91' XR 250 with stock 10.5:1 runs great off 85 octane pump fuel.. just depends on the engine Use 92 and your fine
exmotocrosser
Sep 13, 2019 06:12 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
BYC
Sep 25, 2015 02:10 PM
Sw00p
Sep 24, 2015 02:50 PM
