Is it just me???
Old May 12, 2000 | 12:16 PM
kevin_staton's Avatar
MS Access. MS SQL Server.
Here, drink the Microsoft Kool-aide. It'll make everything better.
Old May 14, 2000 | 02:07 PM
trx430ex's Avatar
Grrrrrr.....*******s!.... There got to be a way?
Hmmmm,,,,,,Running out of options.
As for the slow loading, I 've noticed with zone alarm. Back tracking ileagle probes into my ports. That these threads can travel through thirty different routers before they get to me. And it only takes one to slow it down for whatever reason. The whole net is a mess!
Gabe I need to talk to you, Been working on a big site for a long time. W- cold fusion, It's almost time to bring it to life. Plug and pray!!
Old May 16, 2000 | 01:13 PM
HondaHunter's Avatar
You are limited on the web to the slowest router and server you traverse through.
If you can control the means to the end you'd notice how fast it really is. I'm sure the amount of band width ATV must be buying is enough to accomodate your need for speed.
But be honest, are you content with how fast your Quad goes, or are you always looking for more? Remember, Speed kills. Besides a quote from the Simpsons: "does any one really need that much ****, that fast?"
Allow me to Quote:
"I am on a T1 and have little trouble with any other site I frequent and most are very speedy. Try A T V source or A T V Time if you would like to see a speedier site as they don't process nearly the traffic this one does."
the key phrase is don't process nearly the traffice this one does."
I guess that means that this one is possibly better, not just older.
Old May 16, 2000 | 06:09 PM
  #15
86atc250r's Avatar
I sit and wait for the end server to reply. Not only is the response time slow, throughput is slow as well. I am guessing they have bandwitdth throttling where each connection has a maximum it can download at. I also am a communications technician working in a central office at a tandem switch site, so I am familiar with how everything works together, heck, I am sitting here right now with earplugs in my ears because of the fan noise from the DMS-100/200, the ANS/AOL, UUNET, and Worldnet dialup cabinets and our frame relay switches.
